v10.4.2 -
I want to calculate the mean of all non zero grouped values by “tray”
- How are you trying to achieve it?
Right now I’m using the Table property: show table footer → calculation: mean
- What happened?
The mean values are skewed by the zero values, They only need to consider all the non zero values
A mean value based on all the filled in values in the column -
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
- Did you follow any online instructions? If so, what is the URL?
