Event Hub dashboard
    I want to create a dashboard in Grafana using KQL to see number of Incoming & Outgoing messages on each topics of EventHUbs.
I tried using KubePodInventory & ContainerLog tables in Log Analytics but i couldnot find anything related to messages .
  • What happened?
    I am not getting any data from above tables to use
    I wanted to see the Incoming & Outgoing calls per topic
