See below… only started getting this in the latest version. I’m using Xibo for signage, so I’m stuck with IE11 for the time being…
I will check it out later today. But just to warn you, we are not really supporting IE11 so if it is not an easy fix then we probably won’t fix it.
Related topics
| Topic | Replies | Views | Activity | |
| Internet Explorer(IE) support | 0 | 431 | March 9, 2020 | |
| When I use IE11 , Graph work incorrectly. Grafana does not supports IE? | 5 | 3174 | September 29, 2017 | |
Grafana with Firefox 60 or IE 11
3 | 2299 | April 9, 2020 | |
IE Time setting error
2 | 611 | December 5, 2019 | |
| The image rendering failure occurred after upgrading to version 10.2.2 | 7 | 2397 | May 1, 2024 |
