Error while querying logs on grafana where loki datasource is used
Getting this error in loki logs while trying to fetch lables, we are using alloy agents to push logs to loki and loki i s deploeyed as simpleScalable mode in gke cluster and using gcp bucket as backend
error: code = Unimplemented desc = unknown service logproto.Querier
Current loki config file
    auth_enabled: false
    bloom_build:
      builder:
        planner_address: loki-backend-headless.monitoring.svc.cluster.local:9095
      enabled: false
    bloom_gateway:
      client:
        addresses: dnssrvnoa+_grpc._tcp.loki-backend-headless.monitoring.svc.cluster.local
      enabled: false
    common:
      compactor_grpc_address: 'loki-backend.monitoring.svc.cluster.local:9095'
      path_prefix: /var/loki
      replication_factor: 3
      storage:
        gcs:
          bucket_name: loki-poc-gke
          chunk_buffer_size: 0
          enable_http2: true
          request_timeout: 0s
    compactor:
      compaction_interval: 10m
      delete_request_cancel_period: 10m
      delete_request_store: gcs
      delete_request_store_key_prefix: index/
      jobs_config:
        deletion:
          chunk_processing_concurrency: 3
          deletion_manifest_store_prefix: __deletion_manifest__/
          max_retries: 3
          timeout: 15m
      max_compaction_parallelism: 1
      retention_delete_delay: 2h
      retention_delete_worker_count: 150
      retention_enabled: true
      upload_parallelism: 10
      working_directory: /var/loki/compactor
    distributor:
      max_recv_msg_size: 104857600
      push_worker_count: 256
    frontend:
      scheduler_address: ""
      tail_proxy_url: ""
    frontend_worker:
    index_gateway:
      mode: simple
    ingester:
      chunk_block_size: 2097152
      chunk_encoding: snappy
      chunk_idle_period: 1h
      chunk_retain_period: 30s
      chunk_target_size: 2097152
      concurrent_flushes: 32
      flush_check_period: 20s
      flush_op_timeout: 10m
      lifecycler:
        address: 0.0.0.0
        final_sleep: 0s
        ring:
          kvstore:
            store: memberlist
      max_chunk_age: 1h
      wal:
        checkpoint_duration: 5m
        dir: /var/loki/wal
        enabled: true
    limits_config:
      max_cache_freshness_per_query: 10m
      max_query_length: 30d
      max_query_lookback: 30d
      query_timeout: 600s
      reject_old_samples: true
      retention_period: 672h
      split_queries_by_interval: 15m
      volume_enabled: true
    memberlist:
      bind_addr:
      - 0.0.0.0
      bind_port: 7946
      dead_node_reclaim_time: 30s
      gossip_interval: 1s
      gossip_nodes: 3
      join_members:
      - loki-memberlist.monitoring.svc.cluster.local
      node_name: ${HOSTNAME}
      retransmit_factor: 4
    pattern_ingester:
      enabled: false
    querier:
      engine:
        max_look_back_period: 0s
      max_concurrent: 20
      query_ingesters_within: 3h
      tail_max_duration: 1h
    query_range:
      align_queries_with_step: true
      parallelise_shardable_queries: true
      results_cache:
        cache:
          embedded_cache:
            enabled: true
            max_size_mb: 100
    runtime_config:
      file: /etc/loki/runtime-config/runtime-config.yaml
    schema_config:
      configs:
        index:
          period: 24h
          prefix: index_
        object_store: gcs
        schema: v13
        store: tsdb
    server:
      grpc_listen_port: 9095
      grpc_server_max_concurrent_streams: 1000
      grpc_server_max_recv_msg_size: 104857600
      grpc_server_max_send_msg_size: 104857600
      http_listen_port: 3100
      http_server_read_timeout: 600s
      http_server_write_timeout: 600s
    storage_config:
      bloom_shipper:
        working_directory: /var/loki/data/bloomshipper
      boltdb_shipper:
        index_gateway_client:
          server_address: dns+loki-backend-headless.monitoring.svc.cluster.local:9095
      gcs:
        enable_http2: true
        request_timeout: 0s
      hedging:
        at: 250ms
        max_per_second: 20
        up_to: 3
      tsdb_shipper:
      use_thanos_objstore: false
    tracing:
      enabled: false
    ui:
      enabled: true
That sounds like you are hitting an endpoint that is not the read path. I would double check your Loki endpoint. Send an API call directly and see if it works.
