Hi Team,
I am facing a bug in alert which is pushed through Microsoft teams.
I used external_image_storage=webdav
And here is the configuration;
url =https://www.4shared.com/folder/1Hs7bUf0/Grafana.html
public_url =https://www.4shared.com/folder/1Hs7bUf0/Grafana.html/${file}
username =myid@example.com
password =*******
What should I change? Thanks in advance,
Regards,
Siddharth
t=2019-06-11T08:12:56-0500 lvl=eror msg=“Failed to upload alert panel image.” logger=alerting.notifier error=“Failed to upload image. Returned statuscode 405 body Apache Tomcat/7.0.41 - Error report
HTTP Status 405 - HTTP method PUT is not supported by this URL
<HR size=“1” noshade=“noshade”>
type Status report
message HTTP method PUT is not supported by this URL
description The specified HTTP method is not allowed for the requested resource.
t=2019-06-11T08:12:56-0500 lvl=info msg=“Executing teams notification” logger=alerting.notifier.teams ruleId=32 notification=“Test alert”
This is the error I’m getting when I checked the log file.
