the loki pod couldn’t be deployed in aws eks, how to solve this error?
version:
loki-chart-version: 2.1.1
loki-image version: v2.0.0
version:
Hi @hepyu
Please provide your config - the information you’ve given is not enough to diagnose the problem.
What dannykopping said… The only place in the config I can think of that you would set a date is for the schema. All examples I have seen have the format YYYY-MM-DD without timezone etc.
You should have the config in your values.yaml or you can check the Loki ConfigMap.
I had solved this. The reason is very funny.
The official config have no double quotation mark on the date format, like this:
the official config: no double quotation mark, invalid.
I changed like this ,then ok, so funny:
