Error Handling in Grafana Dashboards
What is the recommended approach for error handling/notification about errors in grafana itself? For example if there are any syntax or backend errors? How can I get notified about those issues by email?
Alerting doesn’t seem to be a good fit (and also does not provide the neccessary data sources) for this from what I understood so far.
Thank you
Hello @hydra1924
Do you mean grafana errors such as logs errors or warning? If yes I recommend you to build an IDS. OpenSearch is a good solution but a little heavy just for this use…
Regards
