Error getting secret value
    11.4.0
    Make my datasource work
    I have my grafana and prom in a docker env. My grafana has provisionned datasources, dashboards and provisionned grafana.ini.
  • What happened?
    Everything was working fine for the 6 past months. And since few days, i began to have those errors :
    logger=secrets.kvstore t=2025-02-07T13:49:57.689111725Z level=error msg=“error getting secret value” orgId=1 type=datasource namespace=prometheus-bla err=“context canceled”
    logger=infra.usagestats.collector t=2025-02-07T13:49:57.689132327Z level=error msg=“Failed to get HTTP client for Prometheus data source” error=“context canceled”. When it occurs, on y dashboards, the panel with the data linked to the query is in failure as the datasource is not reachable.
    I’d like to have my grafana working as it was for the past months.
  • yes, i found several topics related to this error : Cloudwatch Datasource NoData -> error getting secret value · Issue #91122 · grafana/grafana · GitHub : i changed the timeout in grafana.ini (from 30s to 60s) and still have the error
  • Spike in memory usage overnight causing crash · Issue #91496 · grafana/grafana · GitHub : checked memory on my server, was not 100%, resized my server just to be sure, it did not fixed my issue
It’s a long shot but I found one place in codebase that could create such an error. Do you use database? Could it be that the connection to the database is unstable or something like this?
Hi, sorry for the delay, i don’t use database. Here is the docker code :
grafana:
image: grafana/grafana-enterprise
container_name: grafana
restart: on-failure
ports:
- ‘3000:3000’
volumes:
- ./etc/grafana/config/custom.ini:/etc/grafana/grafana.ini:rw
- ./etc/grafana/provisioning/:/etc/grafana/provisioning/
- ./etc/grafana/ldap.toml:/etc/grafana/ldap.toml
env_file: “.env”
environment:
GF_USERS_ALLOW_SIGN_UP: “false”
GF_AUTH_LDAP_ENABLED: “true”
GF_AUTH_LDAP_CONFIG_FILE: /etc/grafana/ldap.toml
Nothing fancy on the grafana.ini, just set the admin password on start.
for those who encounter this issue : the error was generated by a refresh dashboard interval that was faster than the query response from the datasource. Modified the refresh interval and increased the scraping_timeout fixed the issue.
