Hi everyone.
After updating Grafana to v12.4.2, the queries are showing strange characters in the results. The PostgreSQL database is encoded in WIN1252. The system is running on Ubuntu Linux. I’ve tried adjusting the Linux settings without success. Is anyone else in the group experiencing the same problem?
Can you please post the text that should show up in order to test it in our grafana
The correct words to appear, according to the image, are (from Brazilian Portuguese):
Alta Clínica
Permanência
The source database has the encoding ‘WIN1252’.
This only happens with data coming from the source database. Internal Grafana information (titles, for example) appears correctly.
