Enable CORS and set allowed origin via env in k8s manifest
    NA
    I need to enable CORS and set allowed origin on datasource proxy API via k8s manifest envs.
    grafana:
    baseImage: /grafana/grafana
    envs:
    allowed_origins: .*
    enable_cors: true
  • What happened?
    Cors is not getting enabled
    Cors gets enabled and allows requests from allowed origin
    grafana:
    envs:
    allowed_origins: .*
    enable_cors: true
