Grafana Version 8.1.5 and Operating System Mac OS 10.15.7 Catalina -
Trying to embed Grafana Dashboard hosted on “mygrafanadasboard.xom” to the parent application hosted on “myapplication.xom”. -
Used Iframe in the parent application. Allow embedding is set to true and cookie same site is set to none. Used Keycloak as the IDP for the Single sign-on (SSO). -
What happened?
The dashboard is rendering brilliantly on almost all browsers except Safari. Dashboard renders when “Prevent Cross-Site Tracking” is Disabled. -
The dashboard should render irrespective of browsers. -
Grafana keeps looping back the login screen after successful authentication.
A cookie store in safari is cleared of the session cookie. -
Tired modifying Grafana’s Index and Error views to execute the Storage Access API provided by WebKit to get the document access to cookies.
Updates to the Storage Access API | WebKit
It would help if there is a workaround for this issue.
Thanks.
