After switching grafana to HTTPS mode, “Include image” in mail nottification stopped work. Grafana version was v7.0.3 , yesterday I updated to v7.3.6 to see difference (same behavior).
To debug it, I open the source code of the mail, in good mail (when using HTTP), in table class (with image) I can see line with “img src=”
I have the same issue. After switching to HTTPS images in e-mail alerts are not working.
Is there anything in config file that needs to be changed in order to make it work?
I checked the checkbox of the include image, and in the test email, the image is included, but when the alarm is triggered, the image is missing in the notification email, I am using Grafana V8.0, could anyone help me with this issue?
I updated to v8.4.4 and migrated to Unified alerting, but mail notification still dont Include image (with Graph).
Icon for Silence/Go to buttons are visible normally…
I just upgraded to version 9.3.2, where I enabled the dashboardPreviews feature. In there I noticed that it also cannot create an image, after some studying and experimenting I found that I need to set: [plugin.grafana-image-renderer] rendering_ignore_https_errors = true
After that, an image started showing up in email notifications and dashboard previews.
So its solved after two years
