Editor refreshes Query without calling onRunQuery() - Trino Plugin
Hi All,
I am using Trino plugin - https://github.com/trinodb/grafana-trino/blob/main/src/QueryEditor.tsx#L31
But the problem is in Explorer or like when creating a viz. using the Trino data source. Each time I click outside the QuerEditor box a query is executed without requiring to click on RunQuery. Can someone please guide what is needed to be changed in the code for this to work
Regards,
Amit Singh
@horaamit you are pointing to the correct place and it is the plugin deciding to run the query, it is best if you work with the trinodb plugin developers in their github since they most likely don’t keep an eye on these forums.
