Duplicate Dashboard
I’m trying to duplicate a Dashboard. I have seen that using grafana non-cloud there is a save as option. However, i cant seem to find this using grafana cloud. How would i go about creating a duplicate dashboard here?
My Grafana Cloud has “Save as” option. For example:
Are you sure, that you don’t have Save as? I think you have different Grafana versions, where it may be located in different places.
Different versions? isnt there only one grafana cloud? I’m on the free version. Are you on a subscription?
Let’s make it quick. Do you see “Save as” in dashboard settings?
ah dam, there is! :man_facepalming:
thanks!
OK, so I guess you have Grafana 10.x and you was referring to some older Grafana version (where “Save as” has in different place).
