Hi all,
I try to connect grafana to druid - the connection is working and I get results back (list of json objects) but the graph show only the first/oldest “sum_value” e.g. 192.
Any Idea?
Result set:
“response”: [
“timestamp”: “2018-11-25T16:49:00.000Z”,
“result”: {
“pagingIdentifiers”: {
“sensor_md_v8_2018-11-25T07:42:00.000Z_2018-11-26T00:00:00.000Z_2018-11-25T15:49:49.053Z”: 2
“dimensions”: ,
“metrics”: [
“sum_value”
“events”: [
“segmentId”: “sensor_md_v8_2018-11-25T07:42:00.000Z_2018-11-26T00:00:00.000Z_2018-11-25T15:49:49.053Z”,
“offset”: 0,
“event”: {
“timestamp”: “2018-11-25T16:49:01.795Z”,
“sum_value”: 192
“offset”: 1,
“event”: {
“timestamp”: “2018-11-25T16:49:01.815Z”,
“sum_value”: 435
“offset”: 2,
“event”: {
“timestamp”: “2018-11-25T16:49:01.827Z”,
“sum_value”: 239
