Dropdown to select compressor
Is it possible to use dropdown to select compressor fields only in this below image
This is image of dashboard I have created
can you explain a bit more on what you are trying to achieve?
drop downs or variable plugin (much nicer imo)
chrome-capture-2024-7-9
For energy consumption dashboard I want to change compressor graph Like if I select only compressor1 then compressor 1 graph should display using dropdown
I want the same approch for energy consumption time series graph
by the way How you have done this approch can you explain or can you give screenshot for variable configuration
best to read the docu
