So Currently this is my query and i also have a transformation GROUP BY subaccount and it allows me to get (look at the screenshoot).
As you can see in the query i have to manually look for each month that i desire
how can i improve my query (or something else) to obtain each avalaible month
and to preserve my global structure (drilldown subaccount/service)
WITH LastCostPerServicePerMonth AS (
SELECT
subaccount,
service,
measure_value::double AS Cost,
date_format(time, ‘%Y-%m’) AS month,
ROW_NUMBER() OVER (
PARTITION BY subaccount, service, date_format(time, ‘%Y-%m’)
ORDER BY time DESC
) AS rn
FROM $__database.$__table
WHERE $__timeFilter
SELECT
subaccount,
service,
SUM(CASE WHEN month = ‘2025-02’ THEN Cost ELSE 0 END) AS “feb 2025”
FROM LastCostPerServicePerMonth
WHERE rn = 1
GROUP BY subaccount, service
ORDER BY subaccount, service
Hello there!
To avoid manually specifying each month, you can pivot the data using a structure that keeps your original logic, but aggregates costs per month using GROUP BY
and date_format
Try a query like this:
SELECT
subaccount,
service,
date_format(time, '%Y-%m') AS month,
ROW_NUMBER() OVER (
PARTITION BY subaccount, service, date_format(time, '%Y-%m')
ORDER BY time DESC
) AS rn
WHERE $__timeFilter
SELECT
subaccount,
service,
month,
SUM(Cost) AS monthly_cost
WHERE rn = 1
GROUP BY subaccount, service, month
ORDER BY subaccount, service, month
This gives you one row per subaccount/service/month with the corresponding cost.
To pivot months into columns in Grafana, use:
- Add transformation → Group by
- Fields:
subaccount
, service
- Aggregation:
monthly_cost
→ sum
or last
- Add transformation → Labels to fields
- Key field:
month
- Value field:
monthly_cost
Use Organize fields or Field overrides to clean up the display.
No key field or value field option present in Lables to fields.
Hy momo123
this is your requirement??
steps to achive this:
Step 1:Create table and insert data in it
Step 2:Select table visualization and use this query to disply table in grafana panel.
What will happen to this query in 2026 or for 2024?
hardcoded timestamps ('2025-02-15'
, '2025-02-18'
, etc.) into the time
column of the aps_costs
table.
In 2026 or 2024, the hardcoded 2025 dates will fall outside Grafana’s default time range filters, showing no data.
Use NOW() - INTERVAL
instead of fixed dates to keep data within the current time window.
Hard coding those values into the table breaks all kinds of db design rules and standards
On simple example, What iif this db is used in a different country where the date format is different
MM-DD-YYYY
or something altogether different.
Yes, you’re absolutely right!
Using dynamic values like NOW()
makes the database work better across countries and avoids date format problems.
Thanks for pointing it out!
