Hii everyone, I want to make a double bar graph may be its not possible in normal graph panel in grafana… so I downloaded the Multibar graph panel plugin , In Multibar graph panel i am not able to do data links in this panel.Is there any solution to make double bar graph without using multibar graph panel and with that i want data link also…
unfortunately this is not possible
Thanks . but can i get a double bar graph using default graph panel.
ok then please set the answer to solution
