Grafana 8.3.3 on Ubuntu 20.04 -
Filter data out of range from a sensor pull from Prometheus -
That is the question
I have a prometheus datasource that recover data from many sensor (Temperature and humidity in this case)
When the sensor has something wrong he send “-999” value
I would like not to display this -999 value in the graph in grafana
Something like filtering “humidity value” and not display it if not in 0-100% range
Any idea to do it?
If not possible in grafana, it is maybe possible in prometheus?
Thanks
