Dont calc the total in Stat panel
Hello!
I´m using a Stat field, but how I can calc the total consumption from start to stop?:
import "timezone"
import "date"
option location = timezone.location(name: "Europe/Vienna")
from(bucket: "Heizung")
  |> filter(fn: (r) => r["_measurement"] == "Haus")
  |> filter(fn: (r) => r["Bereich"] == "Alles")
  |> filter(fn: (r) => r["_field"] == "Bedarf")
  |> aggregateWindow(every: 1h, fn: mean, createEmpty: true)
  |> yield(name: "mean")
When I aggregate the values as hour, then it seems correct.
Of course, because then he has for each hour a value as kWh.
But can Grafana not calc the total based on time?
