8.2.7 -
To find a documentation about “angular.element(‘grafana-app’).injector().get(‘…’)”
I want to get the “Teams” out of some JS-Code like I can read the current role with "angular.element(‘grafana-app’).injector().get(‘contextSrv’)…
Via Javascript in the HTML-Panel -
What happened?
see above -
- Did you follow any online instructions? If so, what is the URL?
I couldn’t find a documentation about all “angular.element(‘grafana-app’).injector()”-get-Functions.
Thank you for a response!
