Docker Image for Windows Nanoserver
Offer a docker image for windows nanoserver 1809 (Window Server 2019) The responce, speed is impressive with small image size and memory. Good job.
The current docker image has no tags for window nanoserver. I put together a dockerfile for windows nanoserver 1809 (or any other build). Here is a dockerfile starting point using the open source Windows binaries
# escape=`
ARG WindowsServerCoreVersion
ARG GRAFANA_VERSION
ARG GRAFANA_SHA256
FROM mcr.microsoft.com/windows/servercore:$WindowsServerCoreVersion AS installer
ARG GRAFANA_VERSION=$GRAFANA_VERSION
ARG GRAFANA_SHA256=$GRAFANA_SHA256
ARG WindowsServerCoreVersion=$WindowsServerCoreVersion
ENV GRAFANA_VERSION $GRAFANA_VERSION
ENV GRAFANA_SHA256 $GRAFANA_SHA256
ENV POWERSHELL_VERSION 6.1.3
ENV POWERSHELL_SHA256 AA01A6F11C76BBD3786E274DD65F2C85FF28C08B2D778A5FC26127DFEC5E67B3
SHELL ["powershell", "-Command", "$ErrorActionPreference = 'Stop'; $ProgressPreference = 'SilentlyContinue';"]
RUN [Net.ServicePointManager]::SecurityProtocol = [Net.SecurityProtocolType]::Tls12 ; `
	New-Item -ItemType Directory -Force -Path C:\webdownload | Out-Null; `
    Invoke-WebRequest $('https://dl.grafana.com/oss/release/grafana-{0}.windows-amd64.zip' -f $env:GRAFANA_VERSION) -OutFile 'C:\webdownload\grafana.zip' -UseBasicParsing; `
	if ((Get-FileHash C:\webdownload\grafana.zip -Algorithm sha256).Hash -ne $env:GRAFANA_SHA256) { Write-Error 'GRAFANA SHA256 mismatch';exit 1 } `
    Invoke-WebRequest $('https://github.com/PowerShell/PowerShell/releases/download/v{0}/PowerShell-{0}-win-x64.zip' -f $env:POWERSHELL_VERSION) -OutFile 'C:\webdownload\powershellCore.zip' -UseBasicParsing; `
	if ((Get-FileHash C:\webdownload\powershellCore.zip -Algorithm sha256).Hash -ne $env:POWERSHELL_SHA256) { Write-Error 'Powershell SHA256 mismatch';exit 1 } `
	Expand-Archive C:\webdownload\grafana.zip -DestinationPath C:\grafana; `
	Expand-Archive C:\webdownload\powershellCore.zip -DestinationPath C:\PowerShell;
FROM mcr.microsoft.com/windows/nanoserver:$WindowsServerCoreVersion AS base
COPY --from=installer ["C:/PowerShell/", "C:/Program Files/PowerShell"]
COPY --from=installer ["C:/grafana/grafana-${GRAFANA_VERSION}/", "C:/Program Files/Grafana"]
# In order to set system PATH, ContainerAdministrator must be used
USER ContainerAdministrator
RUN setx /M PATH "%PATH%%ProgramFiles%\PowerShell;"
USER ContainerUser
EXPOSE 3000
WORKDIR "Program Files/Grafana"
ENTRYPOINT [ "bin\\grafana-server.exe" ]
HEALTHCHECK --interval=5m `
 CMD pwsh -NoLogo -NonInteractive -NoProfile -Command `
    try { `
     if (((Invoke-RestMethod -Method Get -UseBasicParsing -Uri http://localhost:3000/api/health).database) -eq 'ok') { exit 0 } `
     else { exit 1 }; `
    } catch { exit 1 }
LABEL grafana.version="$GRAFANA_VERSION" `
grafana.license="https://github.com/grafana/grafana/blob/master/LICENSE.md" `
windows.version="$WindowsServerCoreVersion"
