Docker-Compose error when installing OnCall Hobby Edition
when following the Hobby Edition install guide I get the following initial error
docker-compose up -d
ERROR: Version in “./docker-compose.yml” is unsupported. You might be seeing this error because you’re using the wrong Compose file version. Either specify a supported version (e.g “2.2” or “3.3”) and place your service definitions under the services key, or omit the version key and place your service definitions at the root of the file to use version 1.
For more on the Compose file format versions, see Compose specification | Docker Documentation
Hi @ksargent02,
Welcome to the :grafana: community support forums !!
Please review the submission template and include more details:
  • What is your datasource?
  • What visualization panel you are using e.g. time-series, bar chart, histogram etc?
  • What happened?
Lastly, can you please paste your complete docker-compose.yml file so that we can try to test it?
