What Grafana version and what operating system are you using? v9.0.5
We would like to be able to show linux mount %available with data coming from AppDynamics -
We can get Space Available and Space Used for each mount to display through normal queries. -
What happened?
When we tried to use expressions to add Space Available and Space Used together for even one node and one mount, we got a Query: 500 error. -
We expected to see total space. -
Application Infrastructure Performance|AppD tier|Individual Nodes|server name|Hardware Resources|Disks|dev-dm-3|Space Available
Application Infrastructure Performance|AppD tier|Individual Nodes|server name|Hardware Resources|Disks|dev-dm-3|Space Used
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
Query 500 Error - Did you follow any online instructions? If so, what is the URL?
