Hi all
I’ need to display a tank, with liquid and show % filled ? I got a % value to work with and also a Max Litres I can show, and the current Litres in tank.
What is everyone doing.
G
Hi all
G
Hi all
tank.
So, how about a bar graph?
I don’t see what “max litres” has to do with “%”.
Either you want to show litres, or you want to show %, but you can’t do both
at the same time.
I’m currently enjoying the sunshine.
Antony.
could work, was just hoping to be able to have some shape representing something like a tank that I can display filled… to a percentage. ie rather show the outline of the 5000gal and then fill it with yellow over laid.
thinking with all the IoT use cases out there this would be a regular requirement so display say fuel levels, or whatever levels for liquid reservoirs.
G
This is a cool idea. Best solution is it does not exist and you need it build it yourself.
A container plugin with different shapes
outside my capabilities at the moment.
G
