Display Log Quantities in Bar Graphs and Detect Unexpected Logs in Grafana Loki
Grafana v9.0.3 on Linux (Ubuntu 20.04)
I want to display the quantity of logs (categorized by log type) in a bar graph format, while also detecting any unexpected logs that might indicate errors or anomalies.
By creating a dashboard panel in Grafana using a LogQL query that groups logs into categories and displays the count of each log type over time in a bar graph. I also want to set up a system that automatically identifies any new or unexpected log types that haven’t been seen before.
What happened?
The current setup can count and display logs in a bar graph but requires manual configuration for each type of log. I haven’t been able to find an efficient way to automatically detect and categorize unexpected logs.
I expected Grafana to automatically group similar logs, display their counts in bar graphs, and alert me to new or unexpected log types without needing manual configuration for each log type.
Here is an example of the LogQL query I am using: count_over_time({job=“log_file_name”}[1m])
This is giving me the log count but doesn’t automatically classify different types of logs or detect new ones.
No errors in the UI, but the logs are currently only being categorized manually, which is difficult to scale.
