an application provides an URL for displaying a html page. How can this html page be displayed with grafana ( I have only the URL of the page ) ? I saw there exists the plugin aidanmountford-html-panel which I already installed. I’m on Windows 10 and during the installation of this plugin some symlinks were not created
aidanmountford-aidanmountford-html-panel-b67e58c/node_modules/.bin/babel: plugin archive contains symlink which is not allowed. Skipping
aidanmountford-aidanmountford-html-panel-b67e58c/node_modules/.bin/babel-external-helpers: plugin archive contains symlink which is not allowed. Skipping
aidanmountford-aidanmountford-html-panel-b67e58c/node_modules/.bin/babel-node: plugin archive contains symlink which is not allowed. Skipping
aidanmountford-aidanmountford-html-panel-b67e58c/node_modules/.bin/babylon: plugin archive contains symlink which is not allowed. Skipping
aidanmountford-aidanmountford-html-panel-b67e58c/node_modules/.bin/cake: plugin archive contains symlink which is not allowed. Skipping
aidanmountford-aidanmountford-html-panel-b67e58c/node_modules/.bin/coffee: plugin archive contains symlink which is not allowed. Skipping
aidanmountford-aidanmountford-html-panel-b67e58c/node_modules/.bin/dateformat: plugin archive contains symlink which is not allowed. Skipping
aidanmountford-aidanmountford-html-panel-b67e58c/node_modules/.bin/esparse: plugin archive contains symlink which is not allowed. Skipping
aidanmountford-aidanmountford-html-panel-b67e58c/node_modules/.bin/esvalidate: plugin archive contains symlink which is not allowed. Skipping
aidanmountford-aidanmountford-html-panel-b67e58c/node_modules/.bin/grunt: plugin archive contains symlink which is not allowed. Skipping
aidanmountford-aidanmountford-html-panel-b67e58c/node_modules/.bin/js-yaml: plugin archive contains symlink which is not allowed. Skipping
aidanmountford-aidanmountford-html-panel-b67e58c/node_modules/.bin/jsesc: plugin archive contains symlink which is not allowed. Skipping
aidanmountford-aidanmountford-html-panel-b67e58c/node_modules/.bin/json5: plugin archive contains symlink which is not allowed. Skipping
aidanmountford-aidanmountford-html-panel-b67e58c/node_modules/.bin/loose-envify: plugin archive contains symlink which is not allowed. Skipping
aidanmountford-aidanmountford-html-panel-b67e58c/node_modules/.bin/mkdirp: plugin archive contains symlink which is not allowed. Skipping
aidanmountford-aidanmountford-html-panel-b67e58c/node_modules/.bin/nopt: plugin archive contains symlink which is not allowed. Skipping
aidanmountford-aidanmountford-html-panel-b67e58c/node_modules/.bin/regjsparser: plugin archive contains symlink which is not allowed. Skipping
aidanmountford-aidanmountford-html-panel-b67e58c/node_modules/.bin/rimraf: plugin archive contains symlink which is not allowed. Skipping
aidanmountford-aidanmountford-html-panel-b67e58c/node_modules/.bin/rollup: plugin archive contains symlink which is not allowed. Skipping
aidanmountford-aidanmountford-html-panel-b67e58c/node_modules/.bin/semver: plugin archive contains symlink which is not allowed. Skipping
aidanmountford-aidanmountford-html-panel-b67e58c/node_modules/.bin/strip-indent: plugin archive contains symlink which is not allowed. Skipping
aidanmountford-aidanmountford-html-panel-b67e58c/node_modules/.bin/traceur: plugin archive contains symlink which is not allowed. Skipping
aidanmountford-aidanmountford-html-panel-b67e58c/node_modules/.bin/uglifyjs: plugin archive contains symlink which is not allowed. Skipping
aidanmountford-aidanmountford-html-panel-b67e58c/node_modules/.bin/which: plugin archive contains symlink which is not allowed. Skipping
aidanmountford-aidanmountford-html-panel-b67e58c/node_modules/babel-generator/node_modules/.bin/jsesc: plugin archive contains symlink which is not allowed. Skipping
aidanmountford-aidanmountford-html-panel-b67e58c/node_modules/babel-helper-call-delegate/node_modules/.bin/babylon: plugin archive contains symlink which is not allowed. Skipping
aidanmountford-aidanmountford-html-panel-b67e58c/node_modules/babel-helper-function-name/node_modules/.bin/babylon: plugin archive contains symlink which is not allowed. Skipping
aidanmountford-aidanmountford-html-panel-b67e58c/node_modules/babel-helper-replace-supers/node_modules/.bin/babylon: plugin archive contains symlink which is not allowed. Skipping
aidanmountford-aidanmountford-html-panel-b67e58c/node_modules/babel-plugin-transform-es2015-block-scoping/node_modules/.bin/babylon: plugin archive contains symlink which is not allowed. Skipping
aidanmountford-aidanmountford-html-panel-b67e58c/node_modules/babel-plugin-transform-es2015-classes/node_modules/.bin/babylon: plugin archive contains symlink which is not allowed. Skipping
aidanmountford-aidanmountford-html-panel-b67e58c/node_modules/babel-plugin-transform-es2015-computed-properties/node_modules/.bin/babylon: plugin archive contains symlink which is not allowed. Skipping
aidanmountford-aidanmountford-html-panel-b67e58c/node_modules/babel-plugin-transform-es2015-modules-amd/node_modules/.bin/babylon: plugin archive contains symlink which is not allowed. Skipping
aidanmountford-aidanmountford-html-panel-b67e58c/node_modules/babel-plugin-transform-es2015-modules-systemjs/node_modules/.bin/babylon: plugin archive contains symlink which is not allowed. Skipping
aidanmountford-aidanmountford-html-panel-b67e58c/node_modules/babel-plugin-transform-es2015-modules-umd/node_modules/.bin/babylon: plugin archive contains symlink which is not allowed. Skipping
aidanmountford-aidanmountford-html-panel-b67e58c/node_modules/babel-plugin-transform-es2015-parameters/node_modules/.bin/babylon: plugin archive contains symlink which is not allowed. Skipping
aidanmountford-aidanmountford-html-panel-b67e58c/node_modules/grunt-contrib-clean/node_modules/.bin/rimraf: plugin archive contains symlink which is not allowed. Skipping
aidanmountford-aidanmountford-html-panel-b67e58c/node_modules/grunt-contrib-uglify/node_modules/.bin/uglifyjs: plugin archive contains symlink which is not allowed. Skipping
aidanmountford-aidanmountford-html-panel-b67e58c/node_modules/grunt/node_modules/.bin/grunt: plugin archive contains symlink which is not allowed. Skipping
e[32m✔e[0m Installed aidanmountford-html-panel successfully
Maybe someone can guide me on how to display an external URL in grafana.
I’m using Grafana v7.0.3
