Hi community,
Is there a way by which I can disable the Server Admin option/bar which we see on the left side? Is there any configuration option which is available that can help disabling this option?
Create new user in the org, do not using admin as login, If the user already admin, just go to the Admin Panel, select the user and make no admin for that particular Org.
