I am trying to quantify a metric based on a “days_back” variable. The value calculated is correct on my bar charts, but when the other graphs on my dashboard are zoomed in- the calculated value changes. I am not using $__range for my calculation just the “days_back” variable. How do I make my calculation constant regardless of how the graphs change?
If you share your config (screenshot) it would be helpful.
Good Luck
