We use singlestat panel in grafana to monitor systemd services. Dashboard in the picture below is provisioned using JSON, where position for each singlestat i calculated (gridPos). Problem we face is with automatic position adjustment in Y axes. Even if we provide right coordinates in JSON, it is adjusting on its own to up, which stopping us from provisioning position we want. Is there a way to disable adjusting position on its own and each singlestat to keep position provided in JSON file?
Thank you!
Miroslav
