I am using keycloak to connect to grafana dashbord and I want to disable automatic assign “Viewer Role”, using env variable.
I fund role_attribute_strict = true, but it doesn’t work for me
curious. how exactly are you configuring keycloak with Grafana?
I also try to use role_attribute_strict
equal to true
, but it still assigns the Viewer
role as default if I login with a user that has no role.
