Dial: unknown errno 51 error with msg `network is unreachable` with error_code:1213
    MacOS, k6 v0.46.0 ((devel), go1.21.0, darwin/arm64)
    Run k6 scripts
    installing k6 and go
  • What happened?
    Was working earlier and suddenly getting network is unreachable in all urls I provide
    Run normally
k6 run k6-script.js
WARN[0000] Request Failed                                error="Get \"https://test-api.k6.io/public/crocodiles/\": dial tcp 3.230.251.180:443: connect: network is unreachable"
INFO[0000] {"remote_ip":"","remote_port":0,"url":"removed*,"status":0,"status_text":"","proto":"","headers":{},"cookies":{},"body":null,"timings":{"duration":0,"blocked":0,"looking_up":0,"connecting":0,"tls_handshaking":0,"sending":0,"waiting":0,"receiving":0},"tls_version":"","tls_cipher_suite":"","ocsp":{"produced_at":0,"this_update":0,"next_update":0,"revoked_at":0,"revocation_reason":"","status":""},"error":"dial: unknown errno 51 error with msg `network is unreachable`","error_code":1213,"request":{"method":"GET","url":"removed*","headers":{"User-Agent":["k6/0.46.0 (*removed)"]},"body":"","cookies":{}}}  source=console
go install go.k6.io/xk6/cmd/xk6@latest
Hi @karendianne :wave:
Welcome to the forum :tada:
By the looks of it, it does look like the k6 test API might have been inaccessible to your script for a while.
Assuming this hasn’t been resolved organically, could you provide us with a test script reproducing the issue you’re observing? I also see that you seem to be using xk6, if so, which extensions are you trying to use?
That would be helpful in providing us with enough information to find out how to get your script back to a working state.
Thank you :bowing_man:
