Greetings
We working on a project integrating grafana with an IoT backend using the simple json datasource plugin. Until now, it has worked just fine. However, we need to be able to set alarms. By default, the plugin doesn’t support alarms.
We have seen that it it necessary to implement a background process to get the metrics periodically. We are interested in developing the required functionality in order to do so. We have taken a look to other datasources that support alarms, but unfortunately documentation is scarce.
We would appreciate any guide in order to develop such executor. In particular, how to integrate the executor with grafana. It is necessary to complile grafana from source? Which configuration is required?
