Dependent query variables not updating (MongoDB data source)
    9.2.2 (Grafana Cloud)
    Create dependent query variables using the MongoDB data source, ie. available options for variable B is dependent on variable A selection
    Collection contains just two documents:
   {"colour":"red",
    "shape":"square"}
   {"colour":"blue",
    "shape":"triangle"}
Query for primary/parent variable (x):
    test.tc.aggregate([
      {"\$project": {
          "_id": 0,
          "colour": 1
      {"\$group": {
          "_id": "\$colour"
…yields values red and blue as expected.
Query for dependent/child variable (y):
    test.tc.aggregate([
      {"\$match": {
          "colour": "$x"
      {"\$project": {
          "_id": 0,
          "shape": 1
      {"\$group": {
          "_id": "\$shape"
    Toggle between x values (red/blue) causes y dropdown option to update with square/triangle as appropriate
  • What happened?
    y dropdown contains either triangle or square but that value doesn’t change when x is toggled between red and blue. It seems that y dropdown option can only be changed by changing x then making a null change to y’s query, followed by a manual query rerun.
    See above
    No errors
    No
