I am using Grafana with Jaeger data source (combined with Cassandra).
I have two questions:
- Is it possible to remove specific services?
- Is it possible to upload several log files to Grafana persistently?
Thank you in advance,
Andria
Andria
Howdy, thanks for the question.
There is a table with services in Cassandra, but I do not recall it’s name off the top of my head. If you deleted a service from that list it would no longer show up in the service dropdown but the data would still be there. A more involved process could actually seek out all data related to that service and delete it, but you would have to write it from scratch. Also, it is likely you could get a more detailed answer talking to the Jaeger folks. This forum is primarily for the Tempo backend.
If you are interested in aggregating logs, I’m going to suggest the Loki project, but there are many other backends that Grafana supports.
