Hello, I’m looking for a solution for the single state panel.
The problem is it switches to red too fast. The UPTIME for a PC comes in and sometimes the data comes in at a bad time and it turns red, even though there are no more than 10 seconds between the data sets. Can I set the panels to turn red only when the last record is 30 seconds behind?
Grafana version 6.5.1
It’ll switch to red as soon as the query behind it returns a value which
matches the red threshold.
So, that’s measured in seconds?
What’s your red threshold?
What does that mean?
data sets.
What are you trying to measure? What should be red and what should not?
behind?
How about adding “and time < now()-30s” to your query?
Regards,
Antony.
Thanks for the help, that’s exactly what I was looking for. : ) It took some time but now everything works fine, thank you.
