Defining Alerts
I am new to grafana and wanted to define standard alerts as part of escalation matrix where it should triggert the alerts as below:
1.if cpu is more than 60% for 10 mins trigger alert to Teams channel A for every 10 minutes interval it needs to send the alert.
  1. if cpu is more than 90 % for 5 minutes need to trigger the alert.
how can i achieve this.
Here you’re best off with two alerts, especially as it sounds like you’re wanting to have different types of contacts out the back of them?
I have already defined the rules for the same but is there any standard process to define the escalation matrix?
