Grafana docker image
- What are you trying to achieve?
Query SQLite database to retrieve time-based events and plot the corresponding values
- How are you trying to achieve it?
Using the query
select
started_at,
pst_id
from consolidated_results
group by pst_id
- What happened?
The column started_at
is empty. The other columns are correct.
to have data such as 2022-11-09 08:25:13+00:00
- Notes
- The same query done directly on the SQLite file with DB Browser for SQLite returns correct data.
started_at
is ofDATETIME
type. - I am not sure yet that the format is correct for Grafana (I read the the UNIX epoch is better) - right now the date is not being pulled in at all so I would like to fix that first (and as I type this I hope it is not related)
