Datasource plugin: show label instead of value in the UI, and store value only
I’m trying to use this feature “# Segment component displays Value rather than Label #20483” that was fixed by this PR UI: Use SelectableValue as Segment value #20867
I tested it like below where values are all SelectableValue, and it worked fine in the UI. So far so good.
<Segment
  value={query.itemx}
  options={array of selectableValues}
  onChange={ (itemx: SelectableValue) => {onChange({...query, itemx});}}
The query model is tightly coupled with the UI components, so I had to defined the query model like this
export interface MyQuery extends DataQuery {
    itemx: SelectableValue<string>  // originally itemx: string
The above resulted the data saved in the Grafana db to be an object {label:…, value:…, text:…} instead of a string. How can I avoid this?
I attempted to decouple the query models for the DB and the UI, but it wasn’t successful. I had to write a lot of model to model translation code, and the React state management became a huge mess.
TestData datasource QueryEditor. does what I wanted. I got it working for the React functional components as well.
I will see if SegmentAsync works the same way.
For someone landed this page from search here is how to use the objects in the Segment tags.
  1. define a type of your data model e.g. MyModel. The model can be anything
export type MyModel = {
   foo: {
    bar: string
  1. The type of the value and the dropdown option is SelectableValue<MyModel>. The resultant structure is
  label?: string,
  value?: MyModel,
  // and other fields from SelectableValue
  1. The type of the options is Array<SelectableValue<MyModel>>.
let options:  Array<SelectableValue<MyModel>> = [
   {...}, // SelectableValue<MyModel>
  1. The segment tag should be written as
<Segment<MyModel>
          allowCustomValue
          value={value}
          options={options}
          placeholder="select me"
          onChange={(option: SelectableValue<MyModel>) => {
            // your model is accessible as option.value
            console.log(option.value.foo.bar);
            onChange(...);
If you allowCustomValue the entered string is set in the both value and label field. You may want to check like this
if (typeof option.value === "string")  {
// manually entered value
} else {
// selected option
<SegmentAsync> works the same way.
