Dataset/Scalyr Plugin in Grafana integration issues
I am using the free version of Grafana, I’ve tested this method of integrating Grafana with Dataset/Scalyr both on the free trial on Grafana, as well as a local setup on a Digital Ocean Ubuntu droplet.
Integration between Dataset/Scalyr with Grafana, using the Dataset plugin available on Grafana.
By adding the Connections > Data Source, of Dataset on Grafana.
  • What happened?
I received an error of “Plugin health check failed” when trying to connect the Data Source.
I expected it to connect with the Dataset data source.
Dataset API key: I have inserted here the API key for logs READ from my Dataset/Scalyr account.
Dataset URL: https://app.scalyr.com/
The configuration I set up above, results in a “Plugin health check failed”.
Hi Grafana Team,
I’m facing the same issue with grafana-scalyr integration with scalyr-grafana-datasource-plugin.
Grafana version - 9.4.7
scalyr-grafana-datasource-plugin - 3.1.3
error
grafana error logs:
logger=plugin.sentinelone-dataset-datasource level=error msg="error sending request
to DataSet" err="Post \"/api/facetQuery\": unsupported protocol scheme
