Database port change
I am not able to save the .ini file after making the changes, when I try to save, it says you do not have access to open this file please contact administrator. cant change in the port and database inside .ini file in grafana. Please help!
It sounds like you have read only access, because you can open up the file, see the contents, etc. but you cannot save it, correct?
What OS are you running Grafana on?
If Linux, have you tried logging in as root and making the change?
Yes correct, I cant save the changes in the file. My OS is windows 11 and fully up to date. Kindly guide.
How did you install grafana and in what folder and what version is it
