Data_sent in K6 test summary is different in different servers
We have two similar scripts that has several URLs, these test scripts differ by only one change i.e., domainName in the URL
After running the each script, noticed that one testSummary data_sent value >> other testSummary data_sent value.
Is the individual URLs are the cause of the issue or domain server causing the issue?
Note: We have tracked individual URL’s transmitted data from this example Track transmitted data per URL , but we did not find any difference in the amount of data sent using both domains.
Hi @Navaneeth,
Thanks for reaching out, I’ll give a shot at supporting you :wave:
First, I want to clarify a confusion on my side: “that has several URLs, these test scripts differ by only one change i.e., domainName in the URL”, do these domainName point/resolve to the same resource/server? Also, are the several URLS all using the same domain name in the context of a single script, or is it mixed?
Regardless, before even looking at k6, here’s my mental checklist when I read your post:
  • Are those domain names resolving to the same IP?
  • Are all of the URLs using a domain name, or some of them target an IP directly?
  • Are those URLs using the https protocol?
  • Is there a load balancer in front of the resource you’re fetching?
Also, it could be helpful to have some idea of what you scripts look like, would be comfortable posting an anonymized version of them here?
:bowing_man:
Hi Oleiade,
To the best of my knowledge, I will try to give the clarifications that you have asked for. Please find my clarifications under highlighted text in the below email.
Thanks,
Navaneeth
Navaneeth: No, each domainName points to different server, one domainName points to dev server and other to QA, Also all these URLs points to the same domain name in a single script.
Navaneeth: Not sure, we are using azure services
Navaneeth: All URLs use the domainName only.
Navaneeth: Yes, these URLs uses https only.
Navaneeth: We are using azure frontdoor for one of the domain.
