9.1 -
We trying to get audit log form confluent cloud. -
we are trying through Prom-tail with Loki data source to the grafana. -
What happened?
I’m able to get only some of the data via Loki. They are getting mismatched data. And another user is getting different data from the same data source. For example, if an API key is created in the confluent, could those logs appear in grafana, but each user sees different data? User1 is sees only the Createapikey record and user 2 sees only the DeleteAPIKey record, not the create API key. -
Uniform and same data should appear for all users. -
NA -
NA -
yes
