The spike you see represents # of instances available. So we use this to track crashes. However these spikes will often disappear from view, i think b/c of resolution of the chart? It makes it impossible to track these events reliably. What are we doing wrong? Is there a different visualization we should be using? Thanks in advance!!!
If I understand the question correctly, would selecting max
selector in the query solve the problem?
I think we are using max in our selector. The events (spikes) actually flicker in and out of visibility. One minute they will be there, the next not. I assume this is because the time series on the xaxis doesn’t have enough pixels to represent discrete events and so it just hides it from moment to moment. This is either a bug with the chart library or a misuse (by us) of this type/configuration of report.
