This is using 8.1.1 Grafana and using Ubuntu Docker container
Working Data Links on Status History Panel (the option is there to do this and they work for other panels such as bar gauge, gauge, graph)
By using the Data Links option to add a link
What happened?
They do not show up after configuring them
