I’ve got a query that selects values using “or”.
I display the values using dashed lines.
However, the dashes look odd when using “or” in the query. Is there anything I can do about that?
What is odd? Depends on your queries and data, and your graph options? So you have two queries? Two series? Is stack enabled? Can you enable points so we can see the data returned?
