In my dashboard, I have three elements. one dashboard variable and two panels.
the first panel has the following sql code
SELECT DISTINCT
TransportPlatte
FROM [dbo].[TR]
WHERE MeasurementDateUtc BETWEEN $__timeFrom() AND $__timeTo()
GROUP BY TransportPlatte
ORDER BY TransportPlatte;
it returns all the plates produced within the time period. I have added a data link with the following URL
d/d14229ce69ef/${__dashboard}?orgId=1&var-Platte=${__value.raw}
The second element is the dashboard variable with type custom. In the values separated by commas field, I have entered ${Platte}
This part works as expected. When I click on one of the plates, the value for the dashboard variable gets updated to the new plate number. The problem is the next part
SELECT
v.[Position], v.[Thickness]FROM [dbo].[TR] m
JOIN [dbo].[dataTR] v
ON m.MeasId = v.MeasIdWHERE MeasurementDateUtc BETWEEN $__timeFrom() AND $__timeTo()
AND [ThisPlate] = $Platte
ORDER BY m.MeasurementDateUtc DESC;
Here, the panel is just continuously loading. Instead of $Platte when I type in the actual plate number, then it works instantly.
