Dashboard templates with jagged edge Graphite queries
Probably a poor description, but here goes:
So I have two Graphite directories:
myserver.mydomain.memory
myotherserver.aws.mydomain.memory
If I want to make a dashboard with templating, getting myserver and myotherserver to toggle is straightfoward.
What I can’t get to work is having mydomain and aws.mydomain to with templating. I played around with constants/variables, but it seems like each time I either have too many directories or too little directories in my query.
Is there anyway to do this with templating? Or anyway to have a wildcard span Graphite directories?
Like:
myserver.*.memory
myotherserver.*.memory
So then what is in the middle doesn’t matter.
Thanks!
Not possible AFAIK. One option is you can create symlinks to put everything into a consistent tree, but there are some pitfalls there - notably graphite cache lookups won’t match the symlinked metric, only the original, so if you have a busy graphite server you may not see some recent data until it gets flushed to disk.
Thanks! Well at least the symlink gives me a possible out. Our Graphite server isn’t that busy. Maybe a few thousand metrics an hour, but I don’t have exact numbers.
Or I may end up just making two groups of Dashboards. We’ll see what works out.
