I’m trying to build a new dashboard with some panels organized in rows. In the running Grafana everything looks fine, but the json version either in the Edit→ Dashboard→ Settings or in the Export → json file does not contain any trace of the rows:-( There is a layout element in the json now, which did not make it into the docs just yet?! That layout element does only contain panels, which were not moved into rows:-(
Panels, which were in rows are essentially ‘invisible’ on the next import?! I did not check, if the import actually keeps the non-referred elements?!
It looks like the ‘Dashboard Edit UI’ will create a grid layout by default and has only very little support for anything else.
I dug through the Grafana sources and test cases and found a way to create json files , which import with rows;-) I did not try to export them again yet!!
