Hey there,
Thanks for looking at this.
Here’s the dashboard query:
SELECT mean("cpu_usage") FROM "procstat" WHERE "host" =~ /^(HOSTNAMESNIPPED)$/ AND time > 1524380400000ms and time < 1524985199999ms AND "process_name" =~ /^php-fpm.*/ GROUP BY time(5m), "process_name" fill(null)
Every quick range from “last 5 minutes” to “today so far” produces expected graph results. Any other range lists only as many processes as minutes in time(), so if I set time(6m) it displays the graphs of 6 processes at 6m intervals. To display all of the processes I would need to raise the interval to 30m or in some cases more.
Following the “how to troubleshoot metric query issues” i noticed that
partial":true}],"partial":true
Is being attached to results. Does this mean the data is being cut short because there’s too much?
Any advice is appreciated. Will be actively monitoring.
